labview acquisition arduino uno
urgent: request for help
I want to visualize the characteristic (current voltage) and (voltage power) real time of a Pv panel
I install the current and voltage detector and a photoresistance.
I put a potentiometer (2w) to vary the load.
With the aid of an arduino uno card the data acquisition is done to Labview, the program I have prepared is as indicated in the attached document.
unfortunately, the curve displays nothing and the value of are variable throughout the program test.
please how can I repair my program to display the two curve and the different desired value.
(2,683 Views)
You posted an ordinary ask for help message to the forum intended for ideas for new and improved data acquisition products.  I've asked the moderator to move your message.
Since you are new to the forum, I suggest you read the links in this location.  https://forums.ni.com/t5/Using-the-NI-Community/tkb-p/3055
(2,652 Views)
