labview VIs for HP 35670A
The link to the labview VIs for the HP 35670A is no longer valid and the search for the same returns nothing.  Does anyone have the Labview VIs for that instrument?
The last post was back in 2004(see below)
The instrument driver for the HP 35670A is only supported under LabVIEW 6 and 7. You should upgrade to the latest version of LabVIEW in order to use the HP 35670A driver or any of the newer drivers that we release in the future.
The instrument driver for the HP 35670A can be found on our web site at https://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1151
(3,203 Views)
Accepted by topic author gumnut
Why don't you go to the Instrument Driver Network? I don't know what kind of search you did but the driver is certainly still available and can be found by using the search option there.
(3,198 Views)
