10-11-2011 08:10 PM
Hi saamy,
Oh. I mistake. I am sending it now. Please take a look and let me know.
Steve
10-12-2011 08:16 PM
Thanks a lot Steve, Sure I will let u know once am done.
10-18-2011 12:21 AM
Hello Steve,
I am facing a problem When I try to build .vi file inorder to create .EXE file. Its showing Build error like "Shell32.dll"error. I have attached the screenshot of that error message as image file. Plz chk that and let me know if you know the solution.
[my labview version is 10.0 (Labview 2010)]
Thanks in advance
saamy
10-18-2011 01:33 AM
Hi Sammy,
Pls check there is the file (...\windows\system32\shell32.dll)?
If no, you may need to download the file from some other sources. If yes, pls check whether you are able to copy the file to some other folder?
If the file is there and are able to be copied, we shall try to look more deep into the problem.
Steve
10-18-2011 01:51 AM
Yes Steve, that file is present in that path and I can able to copy that file and put it in another folder.
