labview 8.5 exe appearance location
hi all, after i make my labview to exe file, when click the exe, the program will appear on the screen but not in the middle of the screen? how to manually set up the appearance of the exe file so that it will appear on the location i set (i.e. top left corner, right side, bottom or random place on the screen).
another question: is it possible to remove the title bar and the 'X' button of the labview exe form? hi all, after i make my labview to exe file, when click the exe, the program will appear on the screen but not in the middle of the screen? how to manually set up the appearance of the exe file so that it will appear on the location i set (i.e. top left corner, right side, bottom or random place on the screen). another question: is it possible to remove the title bar and the 'X' button of the labview exe form?
(2,734 Views)
These are all settable from VI Properties. Go there and select 'Window Run-Time Position' and 'Window Appearance>Customize'.
p.s. What is a LabVIEW exe 'form'? LabVIEW has a front panel. VB uses forms.
(2,732 Views)
