labview 8.0.1 installer error
hello all,
I am having an issue with building an installer package in labview 8.0.1.  I can build an executable every time, but when i try to build an installer I get the error message in the attatched txt file (its to lengthy to paste here) .  this error happens no matter what switch settings i use in properties, including with and without run-time engine.  I have tried reloading the 8.0.1 upgrade and the same results.  For a variety of reasons I can not goto 8.2 right now to try that...
Any and all suggestions will be appreciated
thanks
Chris
(2,839 Views)
Hi Chris,
Have you tried building a new installer from scratch with new VIs?  Furthermore have you tried to build the installer from another computer?
Nadim
Applications Engineering
(2,818 Views)
 Not yet, but i will give it a shot and let you know
Thank you
Chris
Message Edited by NPI_Chris on 03-15-2007 05:18 PM
(2,815 Views)
