labview 7i problems
the conversion from ascii to decimal is done with labview 2011. But using labview 7i the conversion is not happening. I had done the same mechanism like the numeral in U8 form to indicator. ANd other part is attached to string . Type is given as 0. But the wiring has not happened between the type cast and the numeral. It says they belongs to different forms. SO how can i ovrecome this problem. please help me.
(2,719 Views)
Why are you constantly starting new discussions about the same old thing????
Please keep it all in one place!
continued here (or here)
@perumpadapu wrote:
Type is given as 0.
zero is not a type, it is a value.
(2,700 Views)
