labview 7 web-enable
My host pc was interface to a web-cam via a IMAQ card, the program was written to capture the real-time image. when i tried to web-enable my program using labview 7, i was able to see n control my front panel in real-time at the client pc. But the image window for the web-cam onli appear at the host pc, it does not appear on my client pc. wat happen??
(2,661 Views)
Be sure you aren't running another webserver. If you have IIS services running, there will be a conflict over Port 80. Disable any other web servers and try it again. (You should be getting a error 60 message, as well.)
Good luck!
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,661 Views)
