labview 7.0 with remote pxi target
Dear All,
 I am first time user of labVIEW7.0 & RT 7.0 and pxi.
In my application i am having
PXI chassis -- PXI-1002
Controller    NI PXI-8176
Timer I/Ocard   NI PXI-6602
and 2 Nos. Multifunction I/O NI PXI-6071E
I am using this PXI system as a remote system(IP address 172.24.10.162)  connected to host PC(IP address 172.24.10.163) with ethernet.
I am not able to connect device in MAX. I had tried proceedure  given in MAX help.
In MAX i have tried
     Remote systems >>>Remote Device>>>>Next >>>> IP address  172.24.10.162 >>>Finish
But error message display   " The device at this address is not supported"
If i do ping this system it is responding so network is OK.
I might be done some thing wrong.
Anybody have document for first time user of such application. Please give me and guide me to develop my application.
Message 1 of 9
(3,975 Views)
Vishnu,
working with PXI systems in a way like you describe is only possible for RT targets. If the controller is running in Windows, it's just another "PC".....
If LabVIEW RT is installed on the controller, the system should show itself in MAX without any further configuration if the PXI is in the same subnet as the host.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 9
(3,963 Views)
Dear Norbert,
        Thanks for help.
        Actually i don't know the PXI subnet mask. I know only IP address as it is written on the top and i have checked that if i am sending packet on that it is responding by simple "ping" command. Is there any was to see subnet mask of PXI system?
       I think is subnet mask is not matching then it wouldn't reply to "ping'.
       In past on this system other person was working and right now he is not available. Now i have ot work and i don't have any document. i am new user of LABVIEW  and PXI system.
 Thanks again.
--Vishnu
Message 3 of 9
(3,958 Views)
Vishnu,
if the PXI system is configured correctly (including subnet), it should appear in the "network" area in MAX automatically. Maybe it has an aliasname, so it appears as <YourPXISystemName> in MAX.
If it does not appear, it can have different reasons:
a) active firewall, please try with the firewall deactivated (if acceptable by your IT department!)
b) the system is in another subnet. If gateways are configured correctly, it is possible to ping that system, but it might not appear in MAX.
Maybe you want also look into this thread. It seems a little similar to your issue.....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 4 of 9
(3,952 Views)
Dear Norbert,
          I have tried and finaly i got PXI in MAX.  But now i have permission error- 0xBFFF00A8(VI_ERROR_MPERMISSION). I don't know why now this is coming. What type of permission we have to set.
          Communication link between Development PC and PXI system is Ether net.
--Vishnu.
Message 5 of 9
(3,877 Views)
Dear Norbert,
         Thanks for help. I got connection with my PXI system. Actually previously i was using MAX Version 4.2.1.3001 with his i couldn't get connection. Now i have tried with MAX version 3.0.0.3014 and i get connection with my PXI. Does MAX version matter for Remote PXI connetion?
Thanks again.
--Vishnu
Message 6 of 9
(3,870 Views)
Vishnu ,
   We are glad you go an answer . you will be receving good response everytime you post a query here . Could you please kindly mark the reply which you feel was a sloution as "Solved" so that it could be of help to people in future reference.
Pranchal
Message 7 of 9
(3,846 Views)
Dear Pranchal,
         As i  mentioned in my last post I have used MAX version 3.0.0.3014 and i got connection with PXI. Before that i was using MAX 4.2.1.3001. Thats why i asked that is MAX version does matter in PXI remote connection?
--Vishnu
Message 8 of 9
(3,840 Views)
Dear Norbert,
         Thanks for your help. As i have already written that i could connect to my remote PXI via MAX 3.0.  But when i installed evaluation version of LV8.6, MAX was upgrade to version 4.5. Now In MAX i can see Remote PXI chassis, But Devices in PXI chassis can't visible.    What can be the solution of this?
---Vishnu.
Message 9 of 9
(3,742 Views)
