labview 6.1 and 2012 in same computer problem
Hi, everyone.
I've been using Labview 6.1 for a while and it worked fine for me.
I recently installed Labview 2012 in the same computer and looks like the serial port functions are not working correctly. Every time I try to open a VISA communication example, labview freezes.
I'm guess it's because even if I can install two labview versions in a same computer, the drivers can only be installed once correct?
But I thought labview 6.1 and 2012 can share same VISA driver.
Is there any way I can solve this problem with both labview versions working properly?
Thanks in advanc.
(2,885 Views)
The problem I can see is that while they both support VISA, the 6.1 version would probibly only work with a much older version than what would be installed woth 2012. It's sort of similar to the discussion that is going on in a different thread (except in that case it's about DAQ drivers). NI can't maintain backward compatability indefinately, at some point they have to cut the cord to keep move forward.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,880 Views)
I make builds with LabVIEW 8.2.1 and 2011 and both use serial ports.  I can't say that I've tried lots of scenarios but it seems to be working for me.  I had to leave out Compact Field Point support for LV 2011 because I could not get them both installed for separate LV versions and I only needed it for 8.2.1.
Albert
(2,879 Views)
Accepted by topic author Ashes
The LabVIEW and VISA compatibility chart is here. As you can see, there is no version of NI-VISA that is compatible with both 2012 and your ancient 6.1. In fact, the chart doesn't show any LabvIEW version older than 7.1.1.
(2,873 Views)
Thanks. That's really helpful.
I got another question(might be silly).
Let's see if I have two applications built in both 6.1 and 2012 with visa functions, and they are both working fine.
Can I run them on a save computer installed both 6.1 and 2012 run time engine?
(2,870 Views)
You will most likely still encounter the same problem.  The VISA drivers are a separate component, not part of the run-time, so both run-times will try to use the same VISA libraries unless the problem is specifically inside the VIs and not the library functions they call (which seems unlikely to me).
(2,862 Views)
The solution would be to have several windows installs or virtual computers. If you're running win7 pro you can install XP-mode and install LV6 in that one, or similar.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,855 Views)
