labview 2013 daq assistant missing
I can't see the DAQ assistant in Labview 2013!
Labview 2013 + real-time + fpga
Max 5.5.1
Visa 5.4.0
Device driver august 2013
Why?
Message 1 of 14
(14,560 Views)
You have not listed DAQmx. That is the driver that installs the daq assistant. I would suggest you click on the support tab to get the current version. I'm not sure the August driver included the one you need for 2013 since LabVIEW 2013 was released in August.
Message 2 of 14
(14,559 Views)
I have installed DaqMx 9.8
Message 3 of 14
(14,556 Views)
I have versio 9.8 for the DAQmx driver version
Message 4 of 14
(14,553 Views)
Accepted by RavensFan
Did you install that after you installed LabVIEW? If you didn't, then you should be able to get support by just doing a repair.
Message 5 of 14
(14,550 Views)
Did you install DAQmx AFTER installing LabVIEW?  Can you see any of the DAQmx palette?
Message 6 of 14
(14,547 Views)
I already had the 9.8 installed when I install Labview
Message 7 of 14
(14,543 Views)
And two of us have said that you must install the driver after. The driver cannot add support to a program that does not exist on your pc.
Message 8 of 14
(14,538 Views)
Just did the repair!  Will now reboot the pc to let you guys know!!
Message 9 of 14
(14,530 Views)
Still not available after a repair!!!
Message 10 of 14
(14,528 Views)
