labview 2009 timesync
I am trying to install and use timesync in my sbRIO 9642XT.
I install NI-RIO (full)
Then I install the timesync in custom install.
I wanted to see a board like this:
http://zone.ni.com/devzone/cda/tut/p/id/11466 (Figure 2).
But in MAX I can only see the calendar and the timezone configuration board. The area where the synchronization board is suposed to be is blank.
I am using:
LV2009 SP1
Real-Time 9.0.1
NI-RIO 3.4.0
NI-Timesync 1.1.3 which is compatible to LV2009 SP1: http://joule.ni.com/nidu/cds/view/p/id/2819
NI-Timesync Plugin for software based 1588 1.1.1
MAX 5.0
Does anybody know if these versions are compatibles?
Is the sb-RIO compatible to timesync?
Am I missing any steps?
Thanks!
(2,458 Views)
Hi ander182,
    What is your host OS?
    You try format sbRIO and install software again?
Abel
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(2,405 Views)
