labpython
I am running labpython in LabVIEW and it works fine. I can import several modules into LabVIEW and work with them.
However, I now want to use an external package in Labpython. It is located in "C:\\python25\lib\site-packages"  folder.
When I try to import the package, I get the following error message:
<type 'exceptions.AttributeError'>, 'module' object has no attribute 'argv'
Has anybody had a similar problem before? I also tried to manually update the python server path in the script. But that does not help.
The module works fine when I am running it in Python.
This is all I am trying to execute and it cannot import 'VisionEgg'
import sys
sys.path.insert(0, "C:\Python25\Lib\site-packages")
import VisionEgg
Any help is appreciated.
Chintan
(4,190 Views)
Good Afternoon TRFS,
LabPython is not supported by National Instruments.  However, other customers may have some information for you here, on our forums.  Have you visited www.openg.org?
(4,153 Views)
Hi Chintan,
I'm facing the same issue with LabPython while importing comtypes package. Were you able to solve the issue ?
Sathish
(3,896 Views)
