labVIEW example problem
i have install labview 7.1 development software with driver , on windows xp
i am not able to open example . it shows following errors "CAN NOT FIND LabVIEW SERVICE PORT FROM SERVICE LOCATER YOU WILL BOT BE ABLE TO BROWS DIRECTRY STRUCTRY" while when i make any programme it works
please help to solve this problem
thanks
R.R.YADAV
rryadav@cat.ernet.in
(2,999 Views)
hi Yadav,
LV 7.1 has been giving some problems when you install it and we try to access the example dir,try reinstalling LV if it does not work you can always access the example from the national instruments folder,LV7.1/examples.
vicky
(2,998 Views)
LabVIEW Example Finder uses NI Service Locator in the background. Try to restart the Service Locator and see if that helps. More information on this can be found at the following link.
http://digital.ni.com/public.nsf/websearch/8C00F1144B2CD73E86256DEF00698AC3?OpenDocument
Also, make sure that there is no antivirus or firewall application running in the background when you try to open the example.
Ankita A.
(2,998 Views)
