labVIEW code running control using Timer
I have a LabVIEW code which needs to be timer control in terms of code running. The code should work as follows?
1. Need a timer that resets every 60 seconds.
2. From 0-30 seconds, the code should write the value 0(zero) to Modbus register 9 of slave device address 5
3. from 31 - 60 seconds, the code will write the value 256 to same Modbus register 9 of slave device address 5.
4. The timer will reset to zero  and this loop continues for every 60 seconds.
Does anyone in the forum got an idea or a typical LabVIEW code that can perform the above function?
Message 1 of 9
(4,487 Views)
Put what you want in the case structure.
mcduff
Message 2 of 9
(4,480 Views)
Can you please send me the VI?
Message 3 of 9
(4,475 Views)
It is a snippet, if your have LabVIEW 2018 you should be able to download it and drag it to the block diagram and it will run. Note the code it meant to be in a loop.
What version do you have?
mcduff
Message 4 of 9
(4,470 Views)
I have 2017 version
Message 5 of 9
(4,466 Views)
Loop Example in LabVIEW 2017 attached. You may have to play with the rounding to get it just the way you want it.
mcduff
Message 6 of 9
(4,459 Views)
Thanks. will try it out.
Message 7 of 9
(4,454 Views)
I would just use the Elapsed Time VI in the Timing palette.  It can everything but the case structure for you.
Message 8 of 9
(4,437 Views)
Never used it before, good catch.
mcduff
Message 9 of 9
(4,433 Views)
