labVIEW as HMI
I have worked on Human Machine Interface (HMI) of Delta hardware with the PLC
Need know whether LabVIEW front panel can be used as HMI display & can work on varios applications as HMI works??
(5,902 Views)
Can you be more specific about what you are trying to accomplish? In general, the answer is yes, LabVIEW can be used to create HMI displays.
If you provide a little more context, we can help point you in the right direction.
dK
(5,859 Views)
I have build a ATM machine (simulations only) where it works as per the Genuine machine
want to know whether the same i can simulate in LabVIEW and use front panel as the HMI display
(5,840 Views)
Yes.
(5,827 Views)
LabVIEW is a general purpose programming language with a vast selection of premade user interface widgets that can be interacted with by the user and from the programming side.
So yes LabVIEW can be and is used extensively to create various forms of HMI! Without knowing A LOT more about your specific requirements, this will be the answer that you will get from anyone who has worked with LabVIEW and doesn't discredit it for whatever personal reason.
Rolf Kalbermatter  My Blog
(5,807 Views)
