labVIEW 2009 exe not working on windows 2000
Hello!
I am trying to run an executable file compiled from a labVIEW 2009 SP1 application, which has a 32-bit run time engine. The program and executable was created on a windows 10 PC, and was copied onto a pc with Windows 2000 OS (as it does not connect to wifi). The executable does not run on the old PC, it says that 'This is not a valid Win32 application'.
I tried re-installing the .NET framework 2.0, as already mentioned in one of the older posts, but that did not solve the problem.
Is there any solution for this?
(871 Views)
LabVIEW 2009 is not supported in Windows 10, so it is not really clear what you did. What exactly did you "copy"? Why not create an installer instead?
What does the program do? Are there any drivers involved?
It would help to include a link to the earlier discussion so we don't need to search or guess. Thanks!
(869 Views)
