keyboard navigation with left right keys for a ring
is it possible to use the left/right keyboard keys to control a ring? They do not appear in the keyboard-navigation properties.
It has to work that way, that I can move with the keys through the ring-entries and select the desired entry with <enter>
Many thanks in advance,
                    Magnus
(3,274 Views)
Hi Magnus,
This is not the only way, but I think this is the easiest... use an event structure to detect a keystroke, and if the pressed key is the one you want, update the value of you ring 😉
Message Edité par TiTou le 12-12-2006 10:29 AM
Epictetus
Antoine Chalons
(3,274 Views)
Hi TiTou,
thank you very much!
Just one more thing: if I press now the key, the new value for the ring is immediately active. So you can only jump to the next or the previous element.
I need the function in the same way as if you click with the mouse on the ring, all ring-elements are shown and then you can select one element.
Any idea?
Thx,
          Magnus
(3,254 Views)
Hi Magnus,
Sorry, I haven't found how to do exactly what you're asking for... I made a small VI in which if you press "left" or "right", the ring gets the "key focus" and then you can "scroll" the value with the up/down arrow, but you can't see all the value like if you actually clicked on it...
Hope this helps... 😉
BTW, I don't know in which context you are using LabVIEW, but this point is - IMO - not worth spending hours 😉
Epictetus
Antoine Chalons
(3,247 Views)
