key ENTER as OK button in password
I have an application with several VI. Some of them are restricted and only it can executed if enter a password.
I've created a password VI, but I have a problem:
When the user finish to write the password I want that the key Enter acted as the OK button.
I've been looking for the web and I've found an example http://sine.ni.com/devzone/cda/epd/p/id/3988 , but I haven't achieved to solve the problem.
Vicen.
LV 7.1 / WinXP
(3,118 Views)
Rt-click on the OK button -->> Advanced -->> Key Navigation, now assign the Enter/Return to this button, thats all. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(3,116 Views)
Sorry. Attavhment got missed out. Smiley Sad
(3,113 Views)
Hi vicens,
use an event structure to check for "value change" of the string input - when the password given is ok you can automatically stop the while loop, no OK button needed.
You should rather include a CANCEL button, if someone accidently started the prohibited routine...
(3,107 Views)
Thank you
(3,070 Views)
Hi
In sub password vi it holds latest entered password in the password entered field.
how can we remove entered password/refresh(flush) the password entered field.
Thank you.
(2,800 Views)
hi
i got it.
hari
(2,784 Views)
