kernel32 timer
For my application, i am using a timer which use the Kernel32.dll and give me some transfer time.
The timer give microseconds precision and I need millisecond precision, so this is ok.
But I have to calibrate this timer to validate that the time it delivers to me is correct
Do you know how I can do this or if there is a tool with certification to calibrate and validate ?
Thank you,
you will find the Timer I use
(5,686 Views)
If you only need millisecond, why not use "Tick Count"?
(5,512 Views)
Accepted by topic author Mehdi94
Because my client want a calibration certification of my tool and NI cannot certificate the software.
So I bought a cRIO chassis for use the internal clock of the FPGA which can be certificate
(5,467 Views)
What is the task of the application?
I hope that you are aware that Windows is no real-time OS. Delays in range of multiple ms (<10) is the typical case, range of 100s of ms is common, range of multiple seconds possible.
So a certified timing source above the (potentially uncertified) Windows timer (which is used inside the LV timing functions like "Wait") is questionable in context of Windows....
Norbert
Norbert
Expert: Geometry
(5,465 Views)
Hello Norbert,
Yes this is why we change our cDAQ chassis for a cRIO chassis and now we use the hardware clock of the chassis and the FPGA to measure our transfer time.
(5,459 Views)
@Mehdi94 wrote:
[...]now we use the hardware clock of the chassis and the FPGA to measure our transfer time.
What transfer time are you referring to? cRIO to Host?
Norbert
Norbert
Expert: Geometry
(5,456 Views)
It is a transfer time between a sending and receiving command between two telecommunication equipment.
Now it is okay, It works fine
(5,450 Views)
