keithley kusb 3100, labview i2c protocol?
We are using a Keithley KUSB-3100 data acquisition system in combination with Labview 8.0 (or 8.5) to acquire and analyze data. The problem we encounter is that one of the inputs of the DAQ is a digital input using the i2c protocol. The connection to the DAQ is not the problem, but the problem is that Keithley does not provide a solution to use the i2c protocol with Labview (which NI does with its FPGA module). Does anybody know an adequate solution for this problem? Thanks in advance!
(2,953 Views)
National Instruments provides two different solutions for comunication through i2c protocol. One is using FPGA device the other is a bus-powered USB interface for I2C USB 8451. You could find interesting that NI provide also a driver API for USB 8451.
https://www.ni.com/en/support/downloads/drivers/download.ni-845x-driver-software.html
Even if the the NI-845x software supports only NI hardware maybe could be usefull watch how you can program i2c with LabVIEW and in the NI-845x Software User Manual you can find an overview of the I2C and SPI buses as well as detailed information about the API.
Hope this helps a little.
Clara
(2,924 Views)
