keithley 2400 record data problem
 I use Keithley 2400 to Measure I-V curve, at a sweep mode, like scan the V from 0 to 0.2 V, at low NPLC(eg. 0.1), the data can be recorded very successful and save to data.txt. But when I increase the NPLC (eg. 5 or 10,), this vi usually cause some problem. When the scan votage reach the 0.2 V, the keithley display panel stops at 0.2V and shows this current, the VI still shows at working, and no data recorded in the data.txt. In the correct process, Keithley display panel shoud show the "OFF" and the VI also stop working, and the data recorder correctly. Could some one help me out of this? Thank you very much.
(3,187 Views)
Why can't you stick to a single thread for same topic? Please see here and here
(3,185 Views)
(3,182 Views)
I am so Sorry about that. I am a new member of this forum, and I will remember this. Thanks.
(3,175 Views)
