keep folder name in converting folder to library
Hi
Why when you convert a folder in a library your library don't keep the name
its not handy,
Is there a method to eschew to retype the same name
thanks
(2,624 Views)
What you saw it's the normal behavior, effectively when converting a folder in a library, you will loose your name.
I will do a suggestion.
Nacer M. | Certified LabVIEW Architecte
(2,590 Views)
