keep current cell boarders -- Report Generation Toolkit
I have a template in excel and I am using the Excel Easy Table.vi in order to write a string array to the report. The issue I'm running into is, because it's a template, I already have the boarders formatted the way I want within Excel, but when I write the table it doesn't keep the boarders. Is there any way I can either:
1. Get boarder formatting then set the formatting back to that
2. Stop formatting the boarder in the first place
(2,470 Views)
http://forums.ni.com/t5/LabVIEW/Excel-Easy-Table-Elliminating-Borders/m-p/827961#M376138
found that thread...going to see if it solves my problem
(2,460 Views)
Accepted by topic author GregFreeman
So the above thread didn't quite give me the answer but it lead me in the right direction. I found the apped table to report VI and opened it up. If you dig down you find the Excel_Insert_Table.vi. I used this and set "show gridlines" to false. Took care of the problem.
(2,455 Views)
