joystick get a numerical value different than 0 and 1
But, I need a default case. Otherwise, the program wont run, right? the default case remains as i show in the picture?
Message 11 of 18
(987 Views)
Yes, you should have a default case.  Given your problem, you should have 2 cases: "Default" and "1..4".
GCentral
Message 12 of 18
(978 Views)
The problem is every time I press the button and remaind pressing it, the array will fill of the same value. For example, if I press the button 3, and if dont release, the program will fill the array of 3?
There are any way to send the element to array only when I press the button or only when I release?
capture
Message 13 of 18
(945 Views)
You could compare the new value to the previous (store in a shift register).  Then if they are different, store in your array.
GCentral
Message 14 of 18
(937 Views)
but If I have one random sequence like 1 2 2 3, the program will only store only a two  1 2 3
Message 15 of 18
(933 Views)
Yeah, your answer was totaly correct. I solved the problem...Thank you very much
Message 16 of 18
(925 Views)
So then mark Crossrulz's post as the solution rather than your message which definitely is not the solution.  First you will need to go to the options menu to the upper right of your message to unmark it as the solution.
Message 17 of 18
(903 Views)
I though I was checked Crossrulz's last post. I change it. I choose first Crossrulz post as solution because that was the solution of my post question
Message 18 of 18
(882 Views)
