jki vi error installing packages
I cannot download packages/libraries from JKI VI. For example, when I try to download the OpenG Toolkit I get the following error (see openg picture). I also get a similar type of error when I try to download the powertrain controls device drivers. I am trying to install it on a windows 10 pc with labview 2018.
The following is the error I get when downloading the Powertrain Controls Device Drivers:
Main Package Name: Powertrain Controls Device Drivers (System) v2.160.0.17
Package Name with Error: Powertrain Controls Device Drivers (System) v2.160.0.17
Error Message: VIPM could not install the package drivven_lib_drivven_base_tools_system-2.160.0.17 .
Error Code: 8
Error Source: Create Folder in DF9078D42B4EB533955ADED50F0A58BC->73A5BDB5DE39A116FCA8B48EECAF417C->VIPM ZLIB Extract File (Optimized).vi->E80C6C79E2825D14672C8F35C1DCFFBB->F7C4E276637B8E633B6AFDD1EF2CE94A->OGPM Class.lvlib:9379CFD8CA331CF0E38A98FA9D7316C6->OGPM Class.lvlib:D5B6EB965D0BC09274E3E5144188318D->C816626B524CF3DD3AA4372A60C7FF8E->VIPM Main Window.vi<APPEND>
C:\Program Files (x86)\National Instruments\Shared\CompactRIO\CLIPs
Main Package Name: Powertrain Controls Device Drivers v2.160.0.17
Package Name with Error: Powertrain Controls Device Drivers v2.160.0.17
Error Message: VIPM could not install the package drivven_lib_drivven_base_tools-2.160.0.17 .
Error Code: 8
Error Source: Open/Create/Replace File in 73A5BDB5DE39A116FCA8B48EECAF417C->64F66CF17BFDEECFC99D007FAABFE022->1C3783F9D899991C78D90B278C93351B->4F9E61CEDBE6910285FE1211530F26A8->96DC0328B56514F73D2FABBD74865399->OGPM Class.lvlib:9379CFD8CA331CF0E38A98FA9D7316C6->OGPM Class.lvlib:D5B6EB965D0BC09274E3E5144188318D->C816626B524CF3DD3AA4372A60C7FF8E->VIPM Main Window.vi<APPEND>
C:\ProgramData\JKI\VIPM\cache\drivven_lib_drivven_base_tools-2.160.0.17.spec
(2,125 Views)
Even I get the same error while installing LINX package. Could someone help me sort it out?
(2,093 Views)
It  could be JKI package manager is not runnin as Admin...
Close it - open it as Admin then  see if it has access/overwrite priviliages..
Regards
Jack Hamilton
(1,986 Views)
I think that was the issue as I was connected to Company Domain! Thanks
(1,936 Views)
