java applet will not install in browser
My VI will not install a JAva Applet. I jsut keeps saying "Installing Java Applet" and it never prompts for an install or anything. Any ideas? Is there something extra that I need to do that I am not realizing? I attached a screenshot of the window where is says installing.
(2,952 Views)
I also should have stated, as you can tell from the VI screenshot it is a browser window. I can provide the actual VI if needed.
Thank You,
Andrew
(2,948 Views)
How are you trying to install the java applet? Through a website? Calling an installer?
Could it be that the applet already installed on the computer?
Has it ever worked?
CLD Certified
(2,929 Views)
Accepted by topic author Andrew_Hensley
I figured out the issue. Java is messed up on all kinds of ways on my computer. But to answer your question, the site requires java to run and it can't load java so it never works.
(2,923 Views)
