11-15-2005 08:20 AM
11-16-2005 08:03 AM
I do not really understand what is going on.... In the example you gave, you forgot to save the current value as defaults so we can not see the problem. Nothing appears in the command string!
I tried to reproduce the problem but I do not encounter any issue. (I followed in details the KB). I joined the VI I used.
Regards
David D. - Application Engineer - NI France
11-17-2005 02:23 AM
hi,
sorry about the "default" setting in the control.
The problem is solved here. It is a problem of application font settings. Using System or FixedSys font show the characters in the good orientation.
