ivi configuration of serial settings
I'm using IVI drivers to control an Agilent 33401A DMM.  My question is how to change the serial settings for the IVI driver.  This DMM is on COM5 so I linked my DMM logical name to COM5 in the driver sessions.  When I go to Serial & Parallel ports, I can see my COM5 settings.  I made a dummy LabVIEW application that just initializes, takes a reading, then closes the session.  It works fine.  But, if I want to change any settings, things fall to pieces.  First I changed the serial baud rate in MAX for COM5 from 9600 to 4800 to see if it would not work as I expected.  The problem is it worked just fine.  I tried changing a number of setting in MAX and when that still kept working when it shouldn't have, I even changed in Windows devices.  LabVIEW kept working without issue.  I then tried to change the DMM baud rate to 4800 and get communications to work.  I couldn't.  I rebooted, unplugged, restarted MAX, restarted LabVIEW, and every other stop/restart/reboot you can possibly imagine.  Then when I tried going back to 9600 baud, everything was still not working.  When I say not working, the DMM always has a communication error.  After a whole lot of hair pulling and crazy, I managed to get it to communicate at 9600 baud again without error.  But again, when I try to change settings in MAX for the serial port, nothing works.  it seems like it just gets locked into one setting and I can't change it.
If just using VISA, I could use configure settings to get everything the way it needs to be.  Ultimately, I need to be able to configure the settings for the IVI session programmatically in LabVIEW.  why don't these changes seem to do anything?  and, how can I change them programmatically for an IVI session?
Thanks.
Message 1 of 15
(4,499 Views)
Sir Mutt,
Here is a link to another post which discusses how to change the baud rate in LabVIEW using VISA.
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/how-to-change-BAUD-Rate-dynamically-using-vis...
There is also a Developer Zone on using IVI driver with LabVIEW. That link is below.
http://zone.ni.com/devzone/cda/tut/p/id/4556
Good luck.
Renée M
Message 2 of 15
(4,469 Views)
Thanks Renee, but this is not a VISA session. For the IVI, there is no property for baud rate, etc.  I had scoured through the ivi info I've been able to find, including your second link but none of that helps with this issue.  Any other thoughts?
Message 3 of 15
(4,466 Views)
Sir Mutt,
Unfortunately, I think you'll have to set that in MAX (Measurement and Automation).. Is there a reason you wanted to do it programmatically?
Renée M
Message 4 of 15
(4,463 Views)
We have configuration files with the setup for various equipment.  It would be best to be able to read those and set the values accordingly.
Message 5 of 15
(4,461 Views)
Sir Mutt,
I can't think of anything else off hand, but if you tell me which driver(s) you're using, I could try downloading them and seeing what I can find.
Renée M
Message 6 of 15
(4,458 Views)
the one I've been testing usage with is the Agilent 34401A IVI driver.
Message 7 of 15
(4,456 Views)
Sir Mutt,
I looked up that device, and stopped at this link:
http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=1494698&nid=-536902435.53688093...
Can you tell me which one(s) you're using specifically?
Renée M
Message 8 of 15
(4,454 Views)
I got the IVI driver from the NI site...  http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9419659CE034080020E748...
Thanks for assistance BTW.
Message 9 of 15
(4,452 Views)
Sir Mutt,
You're quite welcome. I'm installing that now and will get back with you shortly with my findings.
Renée M
Message 10 of 15
(4,447 Views)
