issues with executable for an encoder control probably due to dll
ihi
i downloaded the dll from usdigital web site
they say it is a .net assembly
i can make the excutable , it can be run, but there is no connection to the encoder
i did the simple vi ; but still no error; just no connection
best
JBM
Message 11 of 16
(760 Views)
What makes you say there is no connection? Can you provide us with the simple VI you came up with?
______________
Laurent V.
Application Engineer - National Instruments (France)
http://www.ni.com/support
Message 12 of 16
(759 Views)
here is the vi
best
JBM
Message 13 of 16
(755 Views)
It is hard for me to test this VI without the encoder itself. However, I would advise to plug a Simple Error Handler ("Gestionnaire d'erreur simple" in French) to the last QSB_S method node, to allow LabVIEW to report errors. Otherwise, there is a chance you might not get any error message, even if something happened on the way.
Hope this helps,
______________
Laurent V.
Message 14 of 16
(753 Views)
thanks
if i do it with the vi evrything works well , no error and there is a connection with the encoder
when i run the executable , no error even with the Simple Error Handler.
i ahve contacted us digital to address the issue
best JBM
Message 15 of 16
(751 Views)
OK, let me know what they advised.
______________
Laurent V.
Message 16 of 16
(749 Views)
