issues about labview 2009 application builder
first of all, sorry for my poor English ~~~:smileyindifferent:i am not quite sure about whether i could make myself clear for you guys.here it is:
SFX-ZIP archive is choosed as the file format for built-exe in labview 2009.when building any project into exe in labview 2009, you can always turn the suffix of the application file into zip. then use any compress-decompress software to open that file.shocked? right? yes, all the vis that used in your project are there. of course, you can decompress all the vis from the archive.although the block digram is removed during the building process, they still can be dragged into any vi and work perfectly.
this is so insecure both for the application and the source code.how about you?
Message Edited by hunt978 on 05-10-2010 04:16 AM
(2,560 Views)
(2,538 Views)
