isolated unbalanced input
In terms of data aquisitioin:
I think I understand a single ended input (unbalanced?)
I think I understand a diferential input (balanced?, but amp internal ground may be connected to external ground)
I think I understanded a diferential isolated input
(please
differential
(3,253 Views)
I think I understand a single ended input (unbalanced?).
I think I understand a diferential input (balanced?, but amp internal ground may be connected to external ground).
I think I understanded a diferential isolated input.
(please see attached)
What is an "unbalanced isolated input"?  especially terms of the gorunding relationship.
(3,252 Views)
Weel maybe I'm just a little slow.  Mr. Lockhart answered my questioned (who, by the way, happens to have some of the best USB AC Data Aq. for the buck -- a shameless plug for helping me)
Single-ended. An unbalanced input, non isolated. Not suitable for off-ground measurements. Very inexpensive.
Differential. A balanced input, non-isolated. Suitable for off-ground measurements provided that the sum of the common mode and normal mode voltages remains within the measurement range of the amplifier.
Single-ended, floating common. An isolated and quasi-balanced input (the floating common is typically connected to the (-) input of a differential amplifier). Suitable for off-ground measurements up to the breakdown voltage of the isolation barrier, and exhibits very good common mode rejection (100 db typical).
Differential, floating common. An, isolated and balanced input. Suitable for off-ground measurements to the breakdown voltage of the isolation barrier, and exhibits superb common mode rejection (>120 db).
For most industrial application that require isolation, the single-ended floating design provides the best price/performance.
Roger W. Lockhart
DATAQ Instruments, Inc.
241 Springside Dr
Akron, OH 44333
USA
Phone: (330) 668-1444 Ext. 200
Fax: (330) 666-5434
Email: rlockhart@dataq.com
web: http://www.dataq.com
(3,236 Views)
