isi t possible to use multiple VIs with state chart module
I'm trying to make an application using state chart module and I have to use at least to VI that I've developped. I'm having problems when I want to define inputs before creating different states. All my VI's have stop buttons and the I/O that I must use. I have the same problem with the outputs. As seen as I can not define the I/O (moore type machine) I can not neither define the guards and the actions that the state machine has to fallow.
Do you have an idea if we can use multiple VI with that module or do I have to use the old good case+while state machine technique.
Thanks.
(2,745 Views)
Your description sadly does not tell me your problem.
Do you use the VI you mentioned as subVI within two different State Charts? Or do you use the same State Chart in two different applications?
Could you please clearify this?
thanks,
Norbert
Norbert
Expert: Geometry
(2,732 Views)
Sorry hard day at work.
I would like to use two different subVIs in the same machine. One of the subVIs will write data (only numbers) on a worksheet ant the other will read the written data(numbers again).
(2,728 Views)
Accepted by topic author OzBdx
Sure this is possible.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,712 Views)
