is there a way to put a string value from a vi file for the message in the two-button dialog box
any help would be appreciated
(2,771 Views)
Just output the string-value in your vi to the "message"-input terminal of the two-button dialog box. It's easy.
(2,771 Views)
i know how to do that, but i wanted to put in the message like this...the result is *value* is this ok?
e.g. C language code (printf "the result is %d is this ok?", value)
(2,771 Views)
See attachment how this is possible.
(2,771 Views)
thanks, i thought about using the concatenate string and the number to decimal string, but using the number to fractional strings seems to work better
(2,771 Views)
