is there a mouse roll event?
Hi all,
I want to roll a Multicolumn listbox with the mouse roller. The best would be an event case, because I use an event structure.
I can´t solve it with the mouse related events, so is there any possibility to make it?
regards
Mitulatbati
Message 1 of 12
(4,071 Views)
NO. There is no Mouse Roll event for the Multicolumn Listbox even in LV 8.5.
Why do you need it ? What re you trying to achieve with it ?
Can you be a bit elaborate ?
What is your LV version ?
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 12
(4,068 Views)
Well, I have a monitor resolution of 1024 x 768, and a multicolumn listbox with more than 100 rows. It is no problem to scroll with the scrollbar, but it would be more confortable to roll with the mouse. It´s clear, that there is no roll mouse event, but isn´t there any tricky solution to solve this? How can I process the mouse roller activities at all?
regards
Message 3 of 12
(4,062 Views)
A search can do some wonders:
http://forums.ni.com/ni/board/message?board.id=170&message.id=179264#M179264
___________________
Try to take over the world!
Message 4 of 12
(4,060 Views)
tst,
That link of Jonnie's says "Page not found"...
Can you please post the Vi, if you ve ?
Message 5 of 12
(4,054 Views)
I was thinking more of reply 12.
Also, I'm sure you can get to Hamilton's site through Google.
___________________
Message 6 of 12
(4,050 Views)
The key is the Acquire input data.vi, which has an "axis" output cluster with a "scrolling" element.
I have to monitor this, and when the value is negativ => a scroll down happened, when positiv=> scroll up happened.
regards
MB
Message 7 of 12
(4,044 Views)
Another cool thing is that starting in LabVIEW 8.0 (I think), listboxes, tables, and tree controls scroll automatically with the mouse scroll wheel...no code required.
-D
Message 8 of 12
(4,033 Views)
Wait, in labview 8.2 a mouse roll will scroll a multicolumn listbox automatically already.  There is no event generated, but the listbox scrolls fine.
-Devin
I got 99 problems but 8.6 ain't one.
Message 9 of 12
(4,002 Views)
Isn't that what I just said?  😉  This behavior was added in LabVIEW 8.0.
-D
Message 10 of 12
(3,996 Views)
