is symbol computation possible if I use string variable?
I need to solve a very complex equation (in fact it's a 4x4 characteristic equation), but the matix is too complex even with BESSEL, HANKEL functions of the vaiable{variable is also outside bell, hankel functions}, Because of it's complexity, I want to use iterative method: i assume a initial value to the variable, and compute the bessel, hankel function, substitute into the equation and solve for the variable,compare the initial value to the solved value and continue iteration till the solved variable match with my assumed one. But to realize this in LABVIEW seems a little difficult, because I don't know if I can allow LABVIEW compute the determinant of the matrix which is the function of the variable( or eigenva
lue which I'm seeking here).
(2,441 Views)
LabVIEW does not allow for a variable to be placed in a matrix.
For a workaround, consider writing out all the math in LabVIEW. It is very ugly for high dimensions. For instance,
|2 4|
|3 a|= 2a -12
The right hand side of the equation would be easy to code in LabVIEW and it allows for altering the variable a.
(2,441 Views)
