is it possible to view and modify the labview 7.1 code having only the built .exe file?
can anyone help me? is it possible to view and modify the code for a labview 7.1 application having only the application file (.exe)??
it is a signal to noise ratio plotter (amongst other things), but what i want to do is enter the code and modify it so it saves the info of the SNR every hour or so, so as to monitor a link between two equipments during a whole day or even week...
the file is attached, if anyone wants to see it, there is also a "configuration options" file (0 bytes) that i don´t klnow what is for.
thx anyone.
(2,762 Views)
No. It is not possible. You need the code the .exe was generated from.
PaulG.
Retired
(2,759 Views)
As Paul said, "no" it is not possible.  However, there may be some outputs that you could use.  I didn't see any attachment to your post.  Look at the connector pane if there are any outputs that provide the data you are looking for and that you could use inside your own VI.
Message Edited by JoeLabView on 03-12-2008 11:00 AM
(2,749 Views)
