11-10-2009 12:15 AM
is it possible to set the background color of a chart or graph to be transparent?
thanks
Solved! Go to Solution.
11-10-2009 12:17 AM
11-10-2009 12:18 AM - edited 11-10-2009 12:19 AM
Yes it is.
Select Tools palette (View>>Tools palette) and set the chart background as well as the control to transperent.
11-10-2009 12:31 AM
Yes it is possible to do so. Goto View>>Tools Pallete. This will open up a tools pallete which you can use to modify the colours and other viewing options of graphs and anything else on the front panel.
For your purpose u select the background of the graph and click on the "set colour squares" present in the lower bottom corner of the pallete. This will open up a whole range of colors you can select for the purpose. There in the black and white strip of colours, there is a box titled "T" on the right most corner. Select that "T" and your background color will go transparent.
Have a nice day. Happy codings.
11-10-2009 12:34 AM
Lesson: coffee can wait, But Solution wont.
Moral: If you know the solution, post it first then take coffee.
