is it possible to programatically switch the counter terminal in the PWM example?
I have successfully downloaded and executed the Complete PWM example here:
http://www.ni.com/white-paper/2991/en
and I know it works because the oscilloscope shows a pulse train on channel # 1.
When you run the complete PWM example it shows a Lab View GUI that allows you to select which counter terminal to use as shown below:
Instead of manually selecting "Dev1/crt0" or "Dev1/ctr1" I would like to programmatically switch this.
How can this be achieved?
(2,587 Views)
Accepted by topic author invasion2121
The answer is yes.
You can wire a string to the terminal instead of Physical Channel control.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,585 Views)
