is it necessary to use semaphores with shared variables
is it ok to use semaphores with shared variables to prevent race conditions or is that built into the shared variable?
- James
Using LV 2012 on Windows 7 64 bit
(3,244 Views)
I don't have any practical experience with shared variables, but if my understanding is correct, semaphores won't necessarily help you, because they work in a single LabVIEW application instance and shared variables work across instances (and even networks), so there's nothing guaranteeing that someone else won't write to it.
___________________
Try to take over the world!
(3,224 Views)
Semaphores are more of a method to protect a section of code from executing, and as tst as said they won't really help you.  There is nothing inherently harmful about having 2 sections of code trying to write to a shared variable at the same time.  Nothing like a crashed program, scrambled value, or an error message.  What will happen is that whatever happens 2nd is the value that sticks.  So a shared variable can still have the possiblility of race conditions just like local and global variables if you are dealing with multiple writers.  That is really an architecture problem.
(3,220 Views)
Thanks for the input !
What if i were using them as single process variables within the same program.  Would semaphores guarantee that a race condition would not occur, or is that unnecessary?
Message Edited by James R on 04-14-2008 02:16 PM
- James
(3,212 Views)
Try looking at an action engine.
http://forums.ni.com/ni/board/message?board.id=170&message.id=240328&requireLogin=False
I believe it will do what you want.
(3,203 Views)
