iplimage to picture control
Dear Guys,
While integration of opencv libraries in LabVIEW i had struck with this.. I can able to display the processed images in the window handle. i want to display it on the same iplimage(opencv image) to .NET Picture control or LabVIEW Picture in the front panel.. How can i do this. Can someone help me to sort out this issue...
Waiting for your reply.
Silver_Shaper | CLD
(2,967 Views)
Any thoughts.............
Silver_Shaper | CLD
(2,922 Views)
Hi
 You can convert IplImage to Bitmap image to show in .Net Control or Convert IplImage to 2D array to display on to the Picture control of labview.
May this code will help you .
#include "extcode.h"
#include "cv.h" //main OpenCV header
#include "highgui.h" //GUI header
#pragma pack(1)
/*typedef struct {
uint8_t v1;
uint8_t v2;
uint8_t v3;
} TD2;
typedef struct {
int32_t dimSizes[2];
TD2 Cluster[1];
} TD1;
typedef TD1 **TD1Hdl;*/
typedef struct
char status;
int code;
uChar *source;
} er;
typedef struct {
uint32_t elt[1];
} TD1;
#include "lv_epilog.h"
#pragma pack()
_declspec(dllexport) void ColorImageToRGBHexArray( IplImage*a,TD1Hdl Pt,er *error);
if (!a)
error->code =-10002;
error->status=TRUE;
if (error->source == NULL)
error->code =1234;
else
else
if (a->nChannels == 3)
int R,G,B;
int i;
int j;
for(i=0;i<(a->height); i++)
for(j=0;j<(a->width);j++)
B=((uchar *)(a->imageData + i*a->widthStep))[j*a->nChannels + 0];
G =((uchar *)(a->imageData + i*a->widthStep))[j*a->nChannels + 1];
R =((uchar *)(a->imageData + i*a->widthStep))[j*a->nChannels + 2];
(*Pt)->elt[i*a->width +j] = R*65536 +G*256 +B;
else
error->code =-10003;
error->status=TRUE;
Warm Regard
Orooj Ahmed
(2,894 Views)
