ip address string control
I need to obtain a series of IP addresses from a user and my first thought was to pop open a dialog box and allow the user to enter the values into a string control.
I'd like to have the control show the entered IP address in the form 128.0.0.5. with the dots showing for clarity. I can't figure any way to preset the dots at strict positions that won't change. Is this  too much effort for too little results or should I maybe use four string controls or even four numeric controls?
Thanks for any suggestions.
(5,216 Views)
I think using 4 numeric controls is the simplest and you can also assure that a valid number is entered. I dropped 4 U8 controls on a decoration and place a period between each one as shown below. I didn;t play around that much but you could make it look exactly like the IP Address selection in windows for a NIC.
Message Edited by Dennis Knutson on 10-24-2007 10:09 PM
(5,199 Views)
If you are using LabVIEW 8.2 you could try the following XControl
Ton
My LabVIEW Ideas
(5,184 Views)
Thanks for thehelp, guys. four numerical controls does seem to be the easiest way.
That X control is real intersesting. I've never looked into these controls before.
I'm wary of using code that may not be easily maintained or changed by some other programmer down the chain, but I'm certainly going to look into this.
Thanks again
(5,156 Views)
