invoke node
Ciao a tutti, sono un principiante con LabView.
Voglio fare un'interfaccia che contenga una parte ripetuta piu' volte: penso si debba usa invoke node; ho iniziato con un semplice esempio.
Base.vi: contiene un integer input and un integer output collegati tra di loro. Questi due widjet devo essere visibili sull'interfaccia principale
Top.vi: usa Load.vi per generare il reference of Base.vi
Run.vi: passa i parametri a Base.vi
Nell'esempio che allego, per semplicita', ho inserito solo un'instanza di Base.vi...ma anche cosi' non funziona
Message 1 of 9
(5,703 Views)
I'm sorry I don't understand italian... Could you try to ask your question in english ?
Or maybe you should repost your question here, on the italian community
Epictetus
Antoine Chalons
Message 2 of 9
(5,697 Views)
Hi All, I'm beginner using Labview.
I want an UI thant contains more istances of a single part: I think I have to use a "invoke node"; I started with a simple example.
Base.vi: it contains un integer input and an integer output likend one to the other. These two widjets are visible in the main UI.
Top.vi: it's the main UI; it uses Load.vi to generate the reference of Base.vi
Run.vi: it gives the parameters to Base.vi
In the example in attachment, in a simple way, I inserted only one istance of Base.vi...but it does not work.
Message 3 of 9
(5,684 Views)
I am not sure if this is exactly what you want but I think it works. Let me know if it's ok for you.
I changed the settings of Base.vi, if it is set as reentrant, the subpanel won't work because there will be 2 instances of the vi in the memory.
I hope this will help you 😉
Epictetus
Antoine Chalons
Message 4 of 9
(5,677 Views)
thank for your help TiTou....but... you did not find the problem.
If I modifie the input of the Top.vi (outside the SubPanel) I would like see the same value in the output (outside the Subpanel); because the Basei.vi
is a cc between the input and the output; so at each time all widjects should have the same value.
Message 5 of 9
(5,671 Views)
Smiley Indifferent
Is it not what is happenning ??? When I change the value of "input" outside of the subpanel, a short time after, the 3 other controls get the same value. Is it not what you want ?
Epictetus
Antoine Chalons
Message 6 of 9
(5,669 Views)
Yes, sorry, IT'S PERFECT. Maybe I did an error in starting the Top.vi.
Thank you a lot.
Message 7 of 9
(5,664 Views)
You're welcome !
by the way, I am french Smiley Tongue
I am not really a football (I mean soccer) fan but I hope we'll have a nice final this sunday, may the best team win 😉
Epictetus
Antoine Chalons
Message 8 of 9
(5,659 Views)
I used your architecture with my project, and it works well.
               But:
If a want add a new Sub panels with a Base.wi,
this message is showed:
LabVIEW:  Cannot open VI because it is already in a subpanel control.
In attachment there are 2 examples:
1) Top.vi: it works weel (1 sub Panel)
2) Top2.vi does not work (2 sun Panels)
Thank you for your help.
Message 9 of 9
(5,544 Views)
