invert array
I'm having trouble inverting (flipping) an array.
example:
xxx
yyy
zzz
becomes
zzz
yyy
xxx
Im trying to make it happen with a for loop with a delete from array and build array inside, but it's not working.
Any suggestions anybody?
(6,769 Views)
Hi Arend
If it is a 1D array, there is a built-in vi for this operation in the array palette. Its name is "Reverse 1D array".
Doc-Doc
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(6,769 Views)
> example:
> xxx
> yyy
> zzz
> becomes
> zzz
> yyy
> xxx
Besides of most probably not using a shift register and choosing the
worst possible solution in terms of performance you have a function in
the array palette called Reverse 1D Array which does exactly what you want.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(6,769 Views)
Uzytkownik "Arend" napisal w wiadomosci
news:5065000000080000003EEF0000-1079395200000@exchange.ni.com...
> example:
> xxx
> yyy
> zzz
> becomes
> zzz
> yyy
> xxx
Sugest that method:
2D array>>"Transpose 2D Array" function>> FOR loop: "Reverse 1D Array"
function>>(outside FOR)>> "Transpose 2D Array" function
regards
ZbyStS [Mikrobi]
(6,769 Views)
Thanx, that did the trick.
(6,769 Views)
