invert analog signal
Is there any way to invert a analog signal .... not just in the graph but throughout the program?
(5,000 Views)
If the signal is centered around zero all you have to do is use the negate function, or multiply the array by -1.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,997 Views)
If you are using Differential input mode, you could just swap the AI- and AI+ connections around on your analog input channel.
(4,979 Views)
