inverse of hash function
You need to define what you think the original message is supposed to be. The transmit function looks horribly wrong to me so I'm not sure what the orignal message is supposed to look like (anyway it's certainly not secure beyond obfuscation). I strongly supect that transmit needs to be rewritten, you could try to get the blowfish algorithm to work for instance. There's also mention of cryptog but the sight for that is a few years old.
You could also try explaining what transmit is supposed to do.
Message 11 of 23
(2,297 Views)
i am trying to filter to the noise
how to connect string and simulated filter, they r two different data types
Message 12 of 23
(2,250 Views)
As written you cannot turn "concatenated string" back into "original", since a huge amount of information is lost.
Why does the wave need to be encrypted, are you sending it over a network?
If you just want to filter you should be able to find something in the labview examples.
Message 13 of 23
(2,233 Views)
I am trying to filter and look how would be my original signal
Filter is not working, I am getting an error
Is there any way to filter from the string
Message 14 of 23
(2,219 Views)
Sorry, meant dictionary, not hash.  Doh!
A
Message 15 of 23
(2,197 Views)
There is not a way to directly filter from the string.  I would suggest that you filter before you do all of your encrypting.
Brandon Treece
Message 16 of 23
(2,179 Views)
I kept the filter before A/D waveform its working fine
if u take the sinewave (without noise and filter) u r getting a constant output
if u take the sinewave, white noise and filter .    I am not getting a constant ouput, I know this is because of white noise
i dont know the reason behind it.
Message 17 of 23
(2,133 Views)
When you say you are not getting a constant output, do you mean that you are not getting a perfect sine wave out?  If you are it is because there are many frequency elements in noise.  When you set up your filter you are setting up a band of frequencies that you want to reject.  If you know the exact frequency that your sine wave will be, then you can get closer to your original signal.  If your filter is not tight around your wanted frequency some unwanted frequencies can get through the filter.
Brandon Treece
Message 18 of 23
(2,103 Views)
If iam not getting a constant output the sample signal is invalid or valid
Message 19 of 23
(2,091 Views)
how to determine if the samples are valid or not ?
Message 20 of 23
(2,086 Views)
