invalid lv client error
I created a .Net interop assembly with LV2009 and added it to a Visual Studio 2005 VB.net project.  When I run the project I get a "Invalid LV Client" error when it calls one of the functions in the interop assembly.
Anyone got any ideas on this?
Thanks!
Message 1 of 12
(5,176 Views)
Hi there!
It may be one of a couple of issues.
Firstly, does your VI contain any dynamic loading of other VIs, and if so are they set to be always included - essentially a missing dependency?
If this does not move any distance to solving the issue, could you let me know what OS you are using please.
Liam A.
Message 2 of 12
(5,156 Views)
As far as I know this doesn't call any dlls.  This is running on Windows XP SP3.  It's the Eurotherm 35xx instrument driver package found on the NI instrument drivers site that I converted over to an interop assembly.
Message 3 of 12
(5,130 Views)
Hi there again!
Which version or versions of LabVIEW are you running or have you installed on the machine previously?
I will continue to look into this in the meantime.
Liam A.
Message 4 of 12
(5,081 Views)
I have 6.1, 8.5.1, 2009 SP1, and 2010 installed.
Message 5 of 12
(5,072 Views)
Are these all 32 bit or do you have 64 bit installed also?
Liam A.
Message 6 of 12
(5,070 Views)
32bit only
Message 7 of 12
(5,068 Views)
Is this error occuring on the computer that you have created the .NET on or another, and do you have the NI VISA Run-time engine?
Liam A.
Message 8 of 12
(5,063 Views)
This has not been deployed yet - so yes, the error happens on the dev pc.  I have everything installed that comes with the developers suite.  NI Visa RT 4.6.1 is installed.
Message 9 of 12
(5,052 Views)
Hi there,
Here are a couple of things that you could perhaps try to resolve this issue.
Below is the Help link on how to build a .NET Interop,
http://zone.ni.com/reference/en-XX/help/371361F-01/lvhowto/building_a_net_assembly/
it might be a case of making the .NET interop again following the guidance above ensuring every function prototype is properley defined, as this may cause a problem.
Otherwise, you could use the Driver export wizard in LabVIEW 6.1, this is no longer included since LabVIEW 8.2.
Please let me know if this helps!
Liam A.
Message 10 of 12
(5,044 Views)
