interpolate problem
HI!
I have a question. How would it be possible to interpolate an larger area, like the picture in the attachement. Is it possible to inpolate the two jags??
Peter
Labview 7.1 on Windows 2000
(3,145 Views)
Well, you can doa linear interpolation but that won't bring much.
Otherwise you kind of need to know what shape the under-sampled feature SHOULD have before interpolating (Gauss for example).
Why do you need to interpolate this?
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,136 Views)
HI Shane!
This curve describes the geometry of an object. Due to the fixing gear ( to fix the object in the machine) there are two jags and they are not required. I want a curve without those jags. Would it be probably possible to solve this problem with a lowpass filter??
PETER
(3,132 Views)
i have added a real picture of this problem, with the x,y dataset
Message Edited by PETER_AUT on 08-12-2005 09:42 AM
(3,130 Views)
