internal fatal error: image.cpp
Hi all
For a couple of times this week (it was the first 2 times that this error occours) it appeared the error that you can see in the attached pic. I was watching a pretty large block diagram surfing it with the navigation window. I clicked several times the block diagram and the navigation window in order to adjust my view, when suddenly that error appeared. Then LV shut down. I launched the program again and it was all right. What was it? Some ideas? I don't want some critical error in my LV: i mean, i'm not talking about windows Smiley Wink
Kind regards
I love the smell of napalm in the morning
(3,373 Views)
This problem has been fixed in Labview 8.1. So i suggest you to upgrade (Labview 8.2 is the last version).
If you want a work-around to the problem, here you have two possibilities:
  • Hide the front panel before allowing the application to exit. You can do this by creating a property node for the VI and writing 'Hidden', or 'Minimized' to the FP.State property. If your activation of LabVIEW has event structures, you can place this code inside the This VI->Panel Close event. If you do not have event structures, you should disable the close glyph on the window border and implement the above code following your main application code.
  • Convert your application back to a previous version of LabVIEW (such as version 7.0 or 7.1) which is not affected by this error.
Ciao!
(3,363 Views)
