interfacing oscilloscope with PC
I am using an MSOS254A oscilloscope to record/save data. I need to operate it using Labview as in my experiments,  there are many devices in experiments that are running through LabVIEW and oscilloscope need to work with them so I have to use Labview.
I have successfully completed the Labview program for the same and am able to record/save data in a CSV file. There are 2 issues I am  facing while recording the data:
1) I am able to write only amplitude samples, not able to record the time axis.
2)  another issue is, I have to save/record many traces of oscilloscope say 100 traces,for that I used  Vi which writes graph to CSV file and put it in a loop. So loop runs as many times I want to save the traces. The problem is every time the start point of recording is not the same.  ( If I save data in oscilloscope directly using Pen drive or any other disc it saves properly but using LabVIEW it is not). How to fix this issue.
(1,324 Views)
Please post your code to help us understand what you have already done.
Quick and raw answer :
1) your time axis is your acquisition timebase so point number 10 is 10*timebase in seconds
2) need to look at your code for this
(1,313 Views)
