in data 01-03-2018 07:13 AM
New year greetings !!
sir iam currently working on a minor project and it was simulated succesfully in the software. Now my concern is to put this work on hardware using a series of LED displays and a zigbee module to transfer data to and fro i.e.. from system to display unit and viceversa ..
My idea is to display a message to a particular cabin (among few) and then acknowledgement is returned that the msg has been displayed.. this was simulated in software now the doubt is that how can i move forward with real time hardware.. which hardware i need to select to dump this code ? also how do i dump it (any detailed procedures)
cheers !
in data 01-03-2018 07:20 AM
Hi ivan,
how do i dump it
Why do you want to "dump" your code? 😄
a series of LED displays and a zigbee module … which hardware i need
You already seem to know which hardware you want to use in the end.
Now you need some hardware to be able to communicate with your "Zigbee module": read the manual of that module to learn about the options it offers!
